Sonarr version 3.0.9): Mono version (6.12.0.182): Ubuntu 22.04 LTS:
Hello I searched for this but all I found where post back in 2019. So would it be possible to install Sonarr 3 and 4 on the Same Machine? Doesn’t 4 use something different then Mono? This is just temporary of course. I would like to import everything from 3 into 4. If I like 4 better I’ll kill 3.
If you want to upgrade: v4 can load your v3 database/settings if you have those, no need to install v3 again just to be able to upgrade.
If you just want to install sonarr, forget about v3, install v4. v3 is no longer supported by the devs for ages now, and sooner or later you’ll run into issues.
