Sonarr version (exact version): 2.0.0.5054
OS: Windows 10
Debug logs: https://pastebin.com/qe3kqa8F
The latest debug log that was generated by Sonarr after crashing: https://pastebin.com/T1h4v0SQ
Description of issue: A few days ago, I started experiencing crashes on Sonarr after startup. I’ve been trying to find a solution ever since, but unfortunately I haven’t been able to get one.
Sonarr had been running perfectly until this problem started. Now, everytime I run Windows, Sonarr appears to crash after a few seconds (different everytime), but the issue seems to come up whenever Sonarr runs a command to update the library and the artwork for the TV shows.
I’ve tried deleting the database and then importing the TV shows again, with a clean installation, getting all the possible Windows updates, updating Sonarr to the latest develop version… but nothing seems to work. It keeps crashing.
I’ve been loking everywhere for a solution and I have seen that many people are experiencing the same issue. It’s a little bit frustrating, because I really like Sonarr and up until now it has been running smoothly.
Can anybody offer some help, please? Many thanks in advance!
EDIT 1:
After stating my problem in the IRC channel, Taloht suggested to find out the exact way in which Sonarr crases, since the logs created by Sonarr didn’t show anything relevant. I have checked the logs created by Windows and they show that, right before each Sonarr crash, there is a failure which is originated by .NET Runtime and shows the following message:
Application: NzbDrone.exe
Framework version: v4.0.30319
Internal error in the .NET Runtime at IP 738C40E3 (738A0000) with exit code 80131506.
Right after this failure, Sonarr crashes with and the event log shows the following message:
Faulting application name: NzbDrone.exe, versión: 2.0.0.5074, marca de tiempo: 0x5a222863
Faulting module name: clr.dll, versión: 4.7.2600.0, marca de tiempo: 0x59d78b0a
Exception code: 0xc0000005
Fault offset: 0x000240e3
Faulting process id: 0xd2c
Faulting application start time: 0x01d36c72d0db57fb
Faulting application path: C:\ProgramData\NzbDrone\bin\NzbDrone.exe
Faulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
Report Id: 33d836c3-9603-4bfd-9c43-7a11664b59f4
Faulting package full name:
Faulting package-relative application ID:
Here you have two screenshots that show both messages:
