Sonar UI doesn't load, no errors in logs
/Applications/Sonarr.app/Contents/MacOS/NzbDrone.exe - Version 2.0.0.4193
Mono JIT compiler version 4.4.0 (mono-4.4.0-branch/81f38a9 Wed Apr 20 17:10:46 EDT 2016)
TLS: normal
SIGSEGV: altstack
Notification: kqueue
Architecture: x86
Disabled: none
Misc: softdebug
LLVM: yes(3.6.0svn-mono-master/a173357)
GC: sgen
Mac OS X 10.11.4
Sonarr.txt http://pastebin.ca/3628544
Debug logs available via dropbox: https://www.dropbox.com/s/ayvi4z42drvb3am/sonarr_issue_nouiload.zip?dl=0
Loading up the Sonarr home page (or the settings page, or any page) gives me a Javascript error in the console: SyntaxError: Unexpected EOF
(anonymous function) — vendor.js:32704
At some point I had to update to the develop branch to fix some problem or another but lately I’ve been getting this problem. I’ve tried to restoring to two separate databases this month with no luck. I’m afraid to go further back but I suppose I can try. There are no database errors in the log, just some minor stuff.
I cleared cache in browser with the same results. Chrome reports this: Failed to load resource: net::ERR_INCOMPLETE_CHUNKED_ENCODING on the same vendor.js file.
I tried hitting the Url to Sonarr directly, bypassing the nginx reverse proxy and it works, so I doubt this is related to Sonarr directly. If you have a working nginx config, would you mind sharing?
Still plagued by this issue. I thought I had it resolved by bypassing nginx, but on several clients including iOS, Mac, and Windows, I get the loading animation. Sometimes I can get it to load by trying either the settings url, or the series url, but I’m at the point no where no URL will load the Sonarr UI.
I completely dumped the database, uninstalled, re-installed (via brew cask) and then imported my shows into a brand new database. Still the same thing. Loading the settings url on Safari on Mac shows this in the JS Error Console for sonarr/vendor.js?h=scemH4vo96iiq9FFxumCeQ Failed to load resource: cannot parse response
I’m out of ideas!
What do the logs show now? Specifically ((trace logs)) as they show API/HTTP requests and response.
