Sonar not "responsive"
Sonarr version 2.0.0.5163:
Mono version 5.2.0.224:
OS Ubuntu, Docker Image:
https://pastebin.com/kCK73jyR
Everything “clickable” is not responsive, like clicking on “Install Latest” on /system/updates starts the Update process, but it doesn´t show the progress in the bottom right notifications. It is only a gui issue, because it all happens in the Background correctly.
Another example is “Search All Missing” on /wanted/missing. It starts the process, but the gui never realizes that it is finished, i have to reload the page.
If anything else is needed please tell me.
:5720/signalr/negotiate?apiKey=XXXXXXXXXXXXXXXXX Failed to load resource: the server responded with a status of 500 (Internal Server Error)
This error is showed in the console.
Do you have multiple browser tabs/windows with Sonarr loaded?
18-4-3 09:30:21.8|Fatal|ConsoleApp|Address already in use. This can happen if another instance of Sonarr is already running another application is using the same port (default: 8989) or the user has insufficient permissions
Is Sonarr being started multiple times?
The partial error isn’t very helpful, do you have the full error from the log file?
No, just one tab.
https://pastebin.com/aaq1tM8v
Are there logs with the console message you’re seeing? Or is that from the browser’s dev console?
More information about that error would be helpful, 5720 looks like a port, but the logs show Sonarr running on port 8989.
Have you tried another browser? Or without any addons enabled?
Which browser are you using?
Chrome and Edge. It is from the Browser Dev console. 5720 is redirected through docker to 8989.
redirected is technically an incorrect term. You mean via nginx proxy, or docker container port mapping?
i believe it is docker container port mapping. I use bytesized connect. It is basically a click and use. but they don´t give support because it is free to use.
Then I’d recommend you look for a community forum for bytesized connect since I get the feeling it’s rather specific to that environment. Perhaps their discord channel might have other users that had similar issues.
i tried, no luck there, but i ask again.
