Hi,
I’m running Sonarr Ver.2.0.0.2939 on Ubuntu server 14.04 in vbox with media being stored in a shared folder.
Sonarr is able to pass a torrent to deluge but then Sonarr fails to monitor it and import it. It has worked sporadically but usually doesn’t.
Let me know if I can provide any more info and thanks for any help, this is driving me nuts.
trace log
http://pastebin.com/8nGm1nXB
What is one of the torrent names that won’t import?
Its Always Sunny in Philadelphia S10E07 HDTV x264-KILLERS[ettv]
Which version of Deluge?
Is Completed Download Handling enabled in Sonarr?
Are you using a label with Deluge for Sonarr?
It looks like Deluge is reporting a download path that Sonarr can’t process.
Hi markus,
-Deluged 1.3.11, -libtorrent 0.16.17.0
-Yes Completed Download Handling is enabled
-I’m using the default “tv-sonarr” label
I do have an update, initially I had deluge configured to download to “/media/sf_storage/Downloads/Incomplete” folder then move completed downloads to “/media/sf_storage/Downloads”. I have now changed that so that downloads are not moved and just download to “/media/sf_storage/Downloads”.
Now files appear to be monitored but not imported
BTW I really appreciate all the work that you put into fantastic software. I am in the process of migrating to a linux server but have been using it for a while on a windows machine and I have to say that it is brilliant, thanks again
edit: new trace log http://pastebin.com/vbwBBZ3D
What does it show in Activity -> Queue?
Deluge seems to report the path: /media/sf_storage/Downloads
for all downloads (this has come up in another thread as well), I’m not sure if this is a new change or what its doing it, but it means Sonarr can’t import them as its requires a path to a folder (named after the torrent) or directly to the file, but instead Deluge sends back: /media/sf_storage/Downloads
If I go to Activity > Queue they are are showing up (they wern’t when I first posted) and I am able to “force import”.
Update: If I hover over the icon in Queue it says - “Intermediate Download path inside drone factory, Skipping.”
Solved: OK, I had drone factory enabled on the same folder that deluge downloaded to, files imported normally when I disabled drone factory. Is this normal? I was hoping that this could be used to import files downloaded from outside of Sonarr?
Yes that expected, so they don’t collide.
If they’re in the same category/label then Sonarr will handle them, otherwise you need handle them manually.
