Hello
Is it possible to let sonarr to connect to my network drive \RASPBERRYPI3\tv-shows ?
Im using sonarr in docker via OMV5 on a RPi4.In the settings on the “connect” tab, you can add kodi in my case, what do this option do?
/Jerry
Hello
/Jerry
You’d need to map it on the host and add it as a volume to the docker container.
Thanks, but this is a bit over my head. Mayby i can map it the host, but add it in a container as a volume sounds more advanced for me.
/jerry
That’s how you let any container access the filesystem outside the container, otherwise everything would be inside and deleting the container would take everything with it.
Ok, i have to give this a try then.
Hi,
Did you manage to get this working as i’m trying to do the same but I have 2 hard drives linked via unionfs?
I can’t figure out how to add the volumes to Portainer to allow the container to see them?
