Sonaar on QNAP losing config on reboot - Help request
Hi,
I’ve recently bought a qnap 453 and wanted to use Sonaar on it - However, it appears that I lose all configuration of the system (Series config, index etc) on reboot of the device. I’m having another small problem with it, but I’ll post in another question to the forum.
Can anybody suggest how to resolve? My initial thoughts are that the database is reset on restart somehow, but no idea how to resolve that.
Thanks for your help.
Sounds like the storage location set for Sonarr is a folder that is wiped on reboot (temp directory maybe?), this should be handled by the QNAP Sonarr plugin and not put in a location that is wiped on reboot. Sonarr never wipes out its on database.
See http://forum.qnap.com/viewtopic.php?f=320&t=109449&start=119
