Some problem with rtorrent on seedbox and sonarr on local machine
I am trying to get Sonarr to work with my seedbox and rtorrent.
I have completed downloads moved to a folder on my seedbox. This folder is accessible using webdrive/netdrive on my local machin.
When using “Drone Factory” it works perfectly from the webdrive/netdrive folder, but when I try to use CDH it gives me an error.
[/home/seeduser/Torrents/Completed/Sonarr/“filename” is not a valid local path. You may need a Remote Path Mapping.
Under Remote Path mapping I have the following.
Host: address to my seedbox
Remote path: The folder were all completed torrents are moved. /home/seeduser/Torrents/Completed/Sonarr/
Local path: The folder in netdrive/webdrive were the completed files are moved to on my seedbox.
\SERVER\Tal0ne\Torrents\Completed\Sonarr
So what am I doing wrong here? I want to use irc to download my files to rtorrent, give them a label that sonarr understand, and then I want sonarr to prosess the file and move it from my seedbox from the maped folder in web/netdrive to the folder were my shows are located on my local harddrive. When adding \SERVER\Tal0ne\Torrents\Completed\Sonarr to Drone Factory it works, but I was hoping to use CDH.
After a restart of Sonarr it works as I wanted :slight_smile:
