Some Downloads Stuck Randomly and Rarely
Sonarr version (exact version): 2.0.0.5153
Mono version (if Sonarr is not running on Windows): 5.4.0.201
OS: MacOS 10.13.3
Description of issue: Ever so often I have a download that is stuck at 100%. It seems like when it happens the download is trash (just a bunch of text garbage). Is there a setting to make Sonarr check for this or ignore this type of situation and retry?
Unless the download is marked as failed in the download client Sonarr will not remove it and look for another release.
Sonarr’s queue will show exactly why it’s not importing it.
If text garbage means obfuscated filenames, Sonarr shouldn’t have a problem, as long as the download is in a well named folder (that Sonarr can parse and figure out the series + episode).
