Some downloaded episodes not automatically processed
Hi All,
Some of the completed downloads are not processed automatically.
I had 6 episodes of various shows not automatically processed some other shows did go trough automatically.
When i turn on the Drone Factory for a moment the episodes are processed.
I have currently two episodes in the folder where sabnzbd downloaded them:
  • Heartland CA S08E16
  • The Americans 2013 S03E08
here is the debug log: http://goo.gl/xIoigf
sabnzbd and sooner are on the same machine (docker’s in unraid)
Download handling is active
Drone Factory interval is set to 0
Hope some one can shine a light on this and tell me what is going on.
Regards
Rob.
If Drone Factory points the same path that SAB reports (or adjusted path with Remote Path Mapping) then CDH will not process them, create a separate folder for Drone Factory.
System.IO.FileNotFoundException: File doesn't exist: /mnt/user/appdata/sabnzbd/ToSonarr/Heartland CA S08E16 720p HDTV x264-KILLERS/
Your logs are full of these messages (for a bunch of different releases), which is the only thing I see wrong with the setup, is Sonarr expecting them on a different path? If so setup a Remote Path Mapping to change the path SAB reports (remote) to one Sonarr can access (local), use the same name you used for Host in SAB download client settings for the host in the remote path mapping.
Thx Markus, i have made the suggested changes to the Drone Factory path.
I will monitor how the downloads will proceed next.
Hi Markus,
The problem is not solved yet, here is the debug log http://goo.gl/FZn9bm
I have checked the path to the downloaded files and there owners and access rights.
root@mediaserver:/mnt/user/appdata/sabnzbd/ToSonarr# ls -l -R
total 0
drwxrwxrwx 1 nobody users 112 Mar 20 18:59 Castle\ 2009\ S07E17\ 720p\ HDTV\ X264-DIMENSION/
drwxrwxrwx 1 nobody users 120 Mar 20 19:08 Chasing\ Life\ S01E20\ INTERNAL\ 720p\ HDTV\ x264-BATV/
drwxrwxrwx 1 nobody users 120 Mar 20 19:04 The\ Following\ S03E03\ 720p\ WEB-DL\ DD5\ 1\ H\ 264-KiNGS/
./Castle 2009 S07E17 720p HDTV X264-DIMENSION:
total 1030433
-rw-rw-rw- 1 nobody users 1054132578 Mar 16 20:27 Castle.2009.S07E17.720p.HDTV.X264-DIMENSION.mkv
./Chasing Life S01E20 INTERNAL 720p HDTV x264-BATV:
total 998939
-rw-rw-rw- 1 nobody users 1021912009 Mar 17 12:33 Chasing.Life.S01E20.INTERNAL.720p.HDTV.x264-BATV.mkv
./The Following S03E03 720p WEB-DL DD5 1 H 264-KiNGS:
total 1391966
-rw-rw-rw- 1 nobody users 1423978652 Mar 17 16:57 The.Following.S03E03.720p.WEB-DL.DD5.1.H.264-KiNGS.mkv
This is what SABnzbd reported
Name	The Following S03E03 720p WEB-DL DD5 1 H 264-KiNGS
Size	1.4 GB
Status	Completed
Category	sonarr
Path	/mnt/user/appdata/sabnzbd/ToSonarr/The Following S03E03 720p WEB-DL DD5 1 H 264-KiNGS/The.Following.S03E03.720p.WEB-DL.DD5.1.H.264-KiNGS.mkv
Download	Downloaded in 4 minutes 48 seconds at an average of 4.9 MB/s
Source	The.Following.S03E03.720p.WEB-DL.DD5.1.H.264-KiNGS
Unpack	[The.Following.S03E03.720p.WEB-DL.DD5.1.H.264-KiNGS] Unpacked 1 files/folders in 20 seconds
Repair	[The.Following.S03E03.720p.WEB-DL.DD5.1.H.264-KiNGS] Verified in 5 seconds, all files correct
The Following S03E03 720p WEB-DL DD5 1 H 264-KiNGSimage 2 of 50next
Name	Castle 2009 S07E17 720p HDTV X264-DIMENSION
Size	1.0 GB
Status	Completed
Category	sonarr
Path	/mnt/user/appdata/sabnzbd/ToSonarr/Castle 2009 S07E17 720p HDTV X264-DIMENSION/Castle.2009.S07E17.720p.HDTV.X264-DIMENSION.mkv
Download	Downloaded in 3 minutes 35 seconds at an average of 4.8 MB/s
Source	Castle.2009.S07E17.720p.HDTV.X264-DIMENSION
Unpack	[castle.717.720p-dimension] Unpacked 1 files/folders in 15 seconds
Repair	[castle.717.720p-dimension] Verified in 5 seconds, all files correct
Name	Chasing Life S01E20 INTERNAL 720p HDTV x264-BATV
Size	1006 MB
Status	Completed
Category	sonarr
Path	/mnt/user/appdata/sabnzbd/ToSonarr/Chasing Life S01E20 INTERNAL 720p HDTV x264-BATV/Chasing.Life.S01E20.INTERNAL.720p.HDTV.x264-BATV.mkv
Download	Downloaded in 3 minutes 26 seconds at an average of 4.9 MB/s
Source	Chasing.Life.S01E20.INTERNAL.720p.HDTV.x264-BATV
Unpack	[chasing.life.s01e20.internal.720p.hdtv.x264-batv] Unpacked 1 files/folders in 11 seconds
Repair	[Chasing.Life.S01E20.INTERNAL.720p.HDTV.x264-BATV] Verified in 9 seconds, all files correct
Docker Volume mappings Sonarr
/mnt/cache/Downloads/:/downloads:rw
/mnt/user/Series/:/tv:rw
/mnt/user/appdata/sabnzbd/ToSonarr/:/tosonarr:rw
/mnt/user/appdata/sabnzbd/ToDroneFactory/:/todronefactory:rw
/mnt/user/appdata/NzbDrone/:/config:rw
Docker Volume mappings SABnzbd
/mnt/user/appdata/sabnzbd:/config:rw
/mnt/cache/:/mnt/cache:rw
/mnt/user/:/mnt/user:rw
SABnzbd Category settings:
Category: sonarr
Path	: /mnt/user/appdata/sabnzbd/ToSonarr
I hope this info helps to find out why the downloads do not go trough automatically.
Rob.
You need to setup a remote path mapping as I described above. SAB reports one path, but Sonarr sees it as something different.
I tried the remote path, but could not figure it out.
Next i tried to set the paths in the docker for SABnzbd and Sonarr to same paths on the server, this seem to be working good for me.
I have made screenshots from Unraid, SABnzbd and Sonarr so you can see how the settings are, i put them on my Clarify-it site here: http://rvank.clarify-it.com/d/94m4dd
Rob.
Yeah, that would have the same effect, glad to hear its working for you now.
