i see this in activity
Project.Runway.All.Stars.S05E13.(Eng.Subs).SDTV.x264-[2Maverick]
[/home/duelistjp/private/Downloads/Complete/Series/Project.Runway.All.Stars.S05E13.(Eng.Subs).SDTV.x264-[2Maverick]] is not a valid local path. You may need a Remote Path Mapping.
in settings under remote mapping i have it setup like this
host : [MY IP REDACTED]
Remote Path: /home/[USERNAME REDACTED]/private/Downloads/Complete/Series
Local Path: Z:\Processed\Series\
in the logs I see this and it never imports
16-6-10 10:45:04.9|Warn|ArgumentValidator|value [/home/[USERNAME REDACTED]/private/Downloads/Complete/Series/[FILENAME REDACTED] is not a valid Windows path. paths must be a full path eg. C:\Windows
16-6-10 10:45:04.9|Fatal|NzbDroneErrorPipeline|Request Failed
[v2.0.0.4183] System.ArgumentException: value [/home/[USERNAME REDACTED]/private/Downloads/Complete/Series/[FILENAME REDACTED] is not a valid Windows path. paths must be a full path eg. C:\Windows
Parameter name: path
at NzbDrone.Common.EnsureThat.EnsureStringExtensions.IsValidPath(Param1 param) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\EnsureThat\EnsureStringExtensions.cs:line 109 at NzbDrone.Common.Disk.DiskProviderBase.FolderExists(String path) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Disk\DiskProviderBase.cs:line 83 at NzbDrone.Core.MediaFiles.EpisodeImport.Manual.ManualImportService.GetMediaFiles(String path, String downloadId) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\MediaFiles\EpisodeImport\Manual\ManualImportService.cs:line 84 at NzbDrone.Api.ManualImport.ManualImportModule.GetMediaFiles() in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\ManualImport\ManualImportModule.cs:line 28 at NzbDrone.Api.REST.RestModule
1.<set_GetResourceAll>b__32_0(Object options) in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\REST\RestModule.cs:line 111
at CallSite.Target(Closure , CallSite , Func`2 , Object )
at Nancy.Routing.Route.<>c__DisplayClass4.b__3(Object parameters, CancellationToken context)
