[SOLVED] Deluge cases Parser: Parsing string issues
2.0.0.4230
Windows 10 x64
http://pastebin.com/5F7kEPzs
How do I get this to stop??? It’s on an unending loop every 1 minute I get this crap!
I have non of these series. And the last one “The Night Shit” I deleted recently.
Go delete it from your download client history :slight_smile:
What are you talking about? I use SABnzbd and theirs no history to wipe…BUT in deluge there was!
But how come only some got this error, I have loads of torrents that still has the tv-sonarr label
HAHAHA, now that I removed the label for those two I got new ones with the same error! if this is not a bug what is? I should not have to remove the label as soon as the torrent is done…
Sonarr keeps track of active/imported downloads via history. but if you delete a series, it’s history is deleted as well, so sonarr doesn’t know about that old download anymore. So it sees the download on the client api (sab history, or torrent client), and tries to find out what it is.
So yeah, you’ll have to remove the label for any show you deleted and still wanna seed.
Aha! thank you for this clear explanation I appreciate it!
