[solved]Adding 24: legacy does not work
Hi,
Is it possible that adding “24: legacy” is not working? It does not show as season 10 in 24. tvdbid does not work. What am I missing?
Regards,
JP
What’s not working? Looks fine here.
The screenshot shows you searching for it but not sonarr finding it does it? Mine does not find the series.
I stand corrected. Searching for 24 or legacy or the tvdbid does not find it. Searching for exactly “24: legacy” does. Thanks for the help. Still looks like a bug to me though.
You need to prefix a TVDB ID lookup with tvdb:. The issue with searching by title is a TVDB API limitation.
Indeed I missed that. Thanks Markus!
