Snoarr Stuck Loading - Qnap
Hey everyone,
I have been running Sonarr for a while and it is a great program but this week I tried to open Sonarr to check the schedule and I was presented with the grey loading screens with the four dots going back and forth and it won’t go any further. I am running it on a Qnap NAS. I have removed Sonarr, I reinstalled and it came back missing all my settings. I tried to update, it does and then I am stuck at the loading screen again. Tried removing Mono and reinstall but no luck. Any suggestions on how I can get Sonarr back up and running?
Thanks
C
Any errors in the log files?
Any errors in the dev console?
Where are the logs stored on the system since I cant get into Sonarr. I ripped it all out and loaded it again. It will run (ver 2.0.0.3469) but if I upgrade to 2.0.0.3530 that is when it reboots and then freezes.
Not sure if this is accurate, but QNAP is listed here: log files.
So I got it running and was able to load my backup into ver 2.0.0.3469 I tried updating to 2.0.0.3530 and it goes back to loading. It appears as if everything is running in the back ground but the UI is stuck. I rebooted and the log from it starting is below. Thanks for looking.
15-10-29 18:11:52.0|Info|Bootstrap|Starting Sonarr - /share/CACHEDEV1_DATA/.qpkg/QSonarr/NzbDrone/NzbDrone.exe - Version 2.0.0.3530
15-10-29 18:11:52.6|Info|AppFolderInfo|Data
directory is being overridden to [/share/CACHEDEV1_DATA/SONARR_CONFIG]
15-10-29 18:11:53.3|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
15-10-29
18:11:53.7|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone
15-10-29 18:11:53.7|Debug|ProcessProvider| - [5479] NzbDrone
15-10-29 18:11:54.1|Info|
MigrationLogger|*** Migrating data source=/share/CACHEDEV1_DATA/SONARR_CONFIG/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
15
-10-29 18:11:54.4|Debug|MigrationLogger|Took: 00:00:00.3539644
15-10-29 18:11:54.5|Info|MigrationLogger|*** Migrating data
source=/share/CACHEDEV1_DATA/SONARR_CONFIG/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
15-10-29 18:11:54.5|Debug|
MigrationLogger|Took: 00:00:00.0350476
15-10-29 18:11:54.6|Info|Router|Application mode: Interactive
15-10-29 18:11:54.6|Debug|Router|Console selected
OwinHostController|Listening on the following URLs:
15-10-29 18:11:54.6|Info|OwinHostController| http://*:8989/
15-10-29 18:11:54.8|Debug|OwinAppFactory|Attaching
NzbDroneVersionMiddleWare to host
15-10-29 18:11:54.8|Debug|OwinAppFactory|Attaching SignalRMiddleWare to host
NancyMiddleWare to host
15-10-29 18:11:54.9|Info|NancyBootstrapper|Starting NzbDrone API
15-10-29 18:11:55.4|Trace|EventAggregator|Publishing ApplicationStartedEvent
15-10-29
18:11:56.9|Trace|EventAggregator|ApplicationStartedEvent -> UserService
15-10-29 18:11:57.0|Trace|EventAggregator|ApplicationStartedEvent <- UserService
Trace|EventAggregator|ApplicationStartedEvent -> DownloadClientFactory
15-10-29 18:11:57.0|Debug|DownloadClientFactory|Initializing Providers. Count 9
15-10-29 18:11:57.2|
Trace|EventAggregator|ApplicationStartedEvent <- DownloadClientFactory
15-10-29 18:11:57.2|Trace|EventAggregator|ApplicationStartedEvent -> IndexerFactory
Debug|IndexerFactory|Initializing Providers. Count 15
15-10-29 18:11:57.2|Trace|EventAggregator|ApplicationStartedEvent <- IndexerFactory
EventAggregator|ApplicationStartedEvent -> ReconfigureLogging
15-10-29 18:11:59.4|Debug|MetadataFactory|Initializing Providers. Count 4
NotificationFactory|Initializing Providers. Count 17
15-10-29 18:12:01.5|Debug|QualityDefinitionService|Setting up default quality config
15-10-29 18:12:01.7|Info|
SceneMappingService|Updating Scene mappings
15-10-29 18:12:02.2|Debug|DelugeProxy|Url: http://eg.dopj.ca:17289/json Action: auth.login
15-10-29 18:12:02.6|Info|
HousekeepingService|Running housecleaning tasks
15-10-29 18:12:02.7|Debug|HousekeepingService|Starting CleanupAdditionalNamingSpecs
HousekeepingService|Completed CleanupAdditionalNamingSpecs
15-10-29 18:12:02.7|Debug|HousekeepingService|Starting CleanupCommandQueue
HousekeepingService|Completed CleanupCommandQueue
15-10-29 18:12:02.7|Debug|HousekeepingService|Starting CleanupDuplicateMetadataFiles
HousekeepingService|Completed CleanupDuplicateMetadataFiles
15-10-29 18:12:02.7|Debug|HousekeepingService|Starting CleanupOrphanedBlacklist
HousekeepingService|Completed CleanupOrphanedBlacklist
15-10-29 18:12:02.7|Debug|HousekeepingService|Starting CleanupOrphanedEpisodeFiles
15-10-29 18:12:02.8|Debug|
HousekeepingService|Completed CleanupOrphanedEpisodeFiles
15-10-29 18:12:02.8|Debug|HousekeepingService|Starting CleanupOrphanedEpisodes
HousekeepingService|Completed CleanupOrphanedEpisodes
15-10-29 18:12:02.8|Debug|HousekeepingService|Starting CleanupOrphanedIndexerStatus
HousekeepingService|Completed CleanupOrphanedIndexerStatus
15-10-29 18:12:02.8|Debug|HousekeepingService|Starting CleanupOrphanedHistoryItems
15-10-29 18:12:02.9|Debug|
HousekeepingService|Completed CleanupOrphanedHistoryItems
15-10-29 18:12:02.9|Debug|HousekeepingService|Starting CleanupOrphanedMetadataFiles
HousekeepingService|Completed CleanupOrphanedMetadataFiles
15-10-29 18:12:02.9|Debug|HousekeepingService|Starting CleanupOrphanedPendingReleases
15-10-29 18:12:03.0|Debug|
HousekeepingService|Completed CleanupOrphanedPendingReleases
15-10-29 18:12:03.0|Debug|HousekeepingService|Starting DeleteBadMediaCovers
HousekeepingService|Completed DeleteBadMediaCovers
15-10-29 18:12:03.0|Debug|HousekeepingService|Starting FixFutureRunScheduledTasks
HousekeepingService|Completed FixFutureRunScheduledTasks
15-10-29 18:12:03.0|Debug|HousekeepingService|Starting TrimLogDatabase
15-10-29 18:12:03.1|Info|Database|Vacuuming Log
database
15-10-29 18:12:03.2|Info|Database|Log database compressed
15-10-29 18:12:03.2|Debug|HousekeepingService|Completed TrimLogDatabase
HousekeepingService|Starting UpdateCleanTitleForSeries
15-10-29 18:12:03.3|Debug|BrowserService|non-interactive runtime. Won’t attempt to open browser.
15-10-29 18:12:03.7|
Debug|RestSharpExtensions|Validating Responses from [POST] [http://eg.dopj.ca:17289/json] status: [OK]
15-10-29 18:12:03.7|Debug|DelugeProxy|Deluge authentication
succeeded.
15-10-29 18:12:03.7|Debug|DelugeProxy|Url: http://eg.dopj.ca:17289/json Action: web.connected
15-10-29 18:12:04.1|Debug|RestSharpExtensions|Validating Responses
15-10-29 18:12:04.1|Debug|DelugeProxy|Url: http://eg.dopj.ca:17289/json Action: web.update_ui
15-10-29
18:12:04.1|Debug|XemProxy|Fetching alternate names
15-10-29 18:12:04.5|Debug|RestSharpExtensions|Validating Responses from [POST] [http://eg.dopj.ca:17289/json] status:
[OK]
15-10-29 18:12:04.6|Debug|SabnzbdProxy|Url: http://eg.dopj.ca:49090/api?mode=get_config&apikey=&output=json
15-10-29 18:12:05.1|Debug|DelugeProxy|Url:
http://eg.dopj.ca:17289/json Action: core.get_config
15-10-29 18:12:05.4|Debug|RestSharpExtensions|Validating Responses from [POST] [http://eg.dopj.ca:17289/json]
status: [OK]
15-10-29 18:12:05.8|Debug|MonoVersionCheck|mono version is 3.2 or better: 3.10.0
15-10-29 18:12:08.2|Debug|HousekeepingService|Completed UpdateCleanTitleForSeries
15-10-29 18:12:08.2|Debug|HousekeepingService|Compressing main database after housekeeping
15-10-29 18:12:08.2|Info|Database|Vacuuming Main database
15-10-29 18:12:09.9|Info|
Database|Main database compressed
15-10-29 18:12:29.0|Info|RssSyncService|Starting RSS Sync
15-10-29 18:12:29.1|Debug|SabnzbdProxy|Url: http://eg.dopj.ca:49090/api?
mode=queue&start=0&limit=0&apikey=&output=json
15-10-29 18:12:29.1|Debug|FetchAndParseRssService|Available indexers 6
15-10-29 18:12:29.2|Debug|
TorrentRssSettingsDetector|Evaluating TorrentRss feed 'http://www.torlock.com/television/rss.xml
15-10-29 18:12:29.2|Debug|TorrentRssSettingsDetector|Evaluating TorrentRss
feed 'http://www.shazbat.tv/rss/recent?passkey= '
15-10-29 18:12:29.2|Debug|Omgwtfnzbs|Downloading Feed https://rss.omgwtfnzbs.org/rss-download.php?
catid=19,20&user=cchawkeye&api=&eng=1&delay=30
15-10-29 18:12:29.2|Debug|Nyaa|Downloading Feed http://www.nyaa.se/?page=rss&cats=1_37&filter=1&offset=1
15-10-29
18:12:29.2|Debug|KickassTorrents|Downloading Feed https://kat.cr/tv/1/?rss=1&field=time_add&sorder=desc
15-10-29 18:12:29.3|Debug|Wombles|Downloading Feed
http://newshost.co.za/rss/?sec=TV&fr=false
15-10-29 18:12:29.5|Debug|SabnzbdProxy|Url: http://eg.dopj.ca:49090/api?
mode=history&start=0&limit=30&apikey=&output=json
15-10-29 18:12:29.6|Debug|X509CertificateValidationPolicy|Certificate validation for https://kat.cr/tv/1/?
rss=1&field=time_add&sorder=desc failed. RemoteCertificateChainErrors
Hastebin the logs next time, otherwise the formatting falls apart quickly. Not seeing anything odd in the logs though.
Which browser is failing?
Have you tried a different browser?
Any errors in the Dev Console in your browser (F12)?
After the reload Chrome has started working. I added it to compatibility in IE and now it works. Thanks for the help.
It loads slow for me on my QNAP TS259l when viewing it on my iOS devices in iCab Mobile and Safari. It even loads slow once in a while on my MacBook Pro in Firefox. Right now it’s stuck permanently on the Dots scrolling left and right on my iPad. Don’t think there are any dev modes on these iOS apps.
You need to connect it to desktop Safari to debug it, but since it loads on other devices, start with clearing the cache.
