My “[seriessearch] Processing report 210/310” takes quite some time to run every time (± 10 mins or so) and using 40% or so processor on my box, is this normal for large collections or is this something that still needs to be optimised?
Hi Markus, thanks for the prompt response. I have about 600 series, will have to check episode count for you. BTW, really like what you have done, think it will sway me from SB.
The refresh from trakt would, the disk scan should fine after the first run since it doesn’t need to match the files to episodes if it finds a matching path.
Thanks, just to confirm would the “[refreshseries] Scanning disk for xxx” be getting the info from trakt for it’s initial scan? I also noticed that for some reason it’s did not run the RssSyncService in the past 12 hours or so, could this be because it’s busy with the refreshseries?
That part thats scanning the disk (for the series its updating), Updating Info for x is getting data from trakt, which takes a bit of time to process the series and each episode, depending on the number of episodes it can take up to about 10 seconds (maybe longer in some cases).
