Size preference for similar quality of downloads
Version
2.0.0.5252
Mono Version
5.10.1.57
Installed on FreeNas 11.2 as an iocage, managed via windows 10 client
Debug logs:n/a
Is there a way to have Sonarr pick the smallest size release when several are presented of equal quality? For instance if there 2 downloads for an episode, both have quality WEBDL-480p, one is 400MB and the other is 200MB, is there a way to get Sonarr to pick the 200MB release?
Thanks
Don’t think that’s possible because it would always choose the best quality.
But you could check if certain groups do those low quality SD releases.
And add them to the must contain.
