Not sure if this is the correct ‘category’ for this, so if not, I apologise.
I’ve very recently made the switch from Sickbeard to Sonarr, and am loving it so far.One small thing, however, is that in Sickbeard, I had a simple customer .bat file as a post processing script (that would run after all renaming and cataloguing etc) was done.
This script would simply copy the file that Sickbeard had just finished post processing, to E:\Current TV, so that my wife could see what was available to watch.
The extra script I (within a .bat file) used was:
echo n|xcopy %1 “E:\Current TV”
Now that Custom Scripts are added into the main branch of Sonarr (I install on windows 10 via the .exe package), I’m hoping someone can provide a very basic script that will do the same thing?
for the life of me, I can’t get the current one to work. When it runs, I get the following error in the log file:
"EpisodeFileMovingService Unable to set last write time: The process cannot access the file 'I:\TV Shows P-S\South Park' because it is being used by another process"
My current config is as follows (Full Path is **\Script\Test.bat - with Test.bat being the script being run):
