SignalR exception thrown by Task: System.AggregateException
I am getting this error in my logs now and than. Is this something I have to worry about? It is kinda a long error and clutters the log.
/opt/NzbDrone/Microsoft.AspNet.SignalR.Core.dll Warning : 0 : SignalR exception thrown by Task: System.AggregateException: One or more errors occurred ---> System.IO.IOException: Write failure ---> System.Net.Sockets.SocketException: The socket has been shut down
  at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in <filename unknown>:0
  at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0
  at System.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0
  at System.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0
  at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0
 --> (Inner exception 0) System.IO.IOException: Write failure ---> System.Net.Sockets.SocketException: The socket has been shut down
It just means the browser was disconnected and a UI notifcation was sent from the server to the client (thats no longer there), we’ve been working on preventing them to the logs aren’t getting hit with errors that aren’t really errors. I’ll add this one to the list.
Edit: Fixed in develop
