Shows listed an hour later than they really come on
This might be intended. Do you intentionally list shows in the calendar as being on an hour later than they really are? I have 3 shows tonight. Daily Show, Colbert Report, and Suits. They’re all listed an hour later than they really come on. I’m worried that for dailies like The Daily Show and The Colbert Report that this might be deceptive. Think it would be possible to set them on their right time, but not start searching until they’ve ended?
Posted in the v2 thread: Times may be off by an hour due to trakt not reporting the proper time for shows airing in EDT (shows GMT-5 instead of GMT-4).
Can’t do anything about this, I noticed its right for some shows so we can’t blindly override it either.
NzbDrone also doesn’t search for shows (unless you invoke a search yourself), it checks the indexers RSS feeds for new releases.
For shows like Suits this doesn’t seem to be much of an issue, but it seems to be causing issues with the Daily Show. Since it airs at 11PM, shifting it forward an hour also shifts the air date of the show, so 11PM on 7/29 becomes 12AM on 7/30, the net result of this being that shows airing on a Monday are ignored and have to be picked up manually.
The displayed date time is not actually used in the matching (display and missing only), there was an issue if you were in a GMT+ timezone, but that was resolved Monday.
