Hey there,
I think that there should be some info added at the /episode endpoint of the api:
"seriesId": 36,
"episodeFileId": 9964,
"seasonNumber": 4,
"episodeNumber": 13,
"title": "Do No Harm",
"airDate": "2021-05-05",
"airDateUtc": "2021-05-06T01:00:00Z",
"overview": "Bravo is tasked with bringing a defecting Boko Haram lieutenant into U.S. custody, but the mission goes sideways when the target gets attacked. Sonny drops the ball as Bravo’s rep on the USS Keating, and the entire team pays the price.",
"episodeFile": {
"seriesId": 36,
"seasonNumber": 4,
"relativePath": "Season 4/SEAL Team - S04E13 - Do No Harm.mkv",
"path": "/home/cas/plex-media/series/SEAL Team/Season 4/SEAL Team - S04E13 - Do No Harm.mkv",
"size": 190263297,
"dateAdded": "2021-05-06T06:20:16.929384Z",
"sceneName": "Seal.Team.S04E13.720p.WEB.x265-MiNX[eztv.re]",
"quality": {
"quality": {
"id": 5,
"name": "WEBDL-720p",
"source": "web",
"resolution": 720
"revision": {
"version": 1,
"real": 0,
"isRepack": false
"language": {
"id": 1,
"name": "English"
"mediaInfo": {
"audioChannels": 2,
"audioCodec": "AAC",
"videoCodec": "x265"
"originalFilePath": "Seal.Team.S04E13.720p.WEB.x265-MiNX[eztv.re].mkv",
"qualityCutoffNotMet": true,
"id": 9964
"hasFile": true,
"monitored": true,
"absoluteEpisodeNumber": 77,
"unverifiedSceneNumbering": false,
"id": 6686
I think there should be info about the following:
When you (in the web ui) click the preview rename option for a series, you get to see the files with “wrong” naming and the suggested new name. That should also be shown in the api output:
"seriesId": 36,
"seasonNumber": 4,
"episodeFile": {
"seriesId": 36,
"seasonNumber": 4,
"size": 190263297,
"naming": {
"correctFileName": false,
"currentFileName": "SEAL Team - S04E13 - Do No Harm.mkv",
"suggestedFileName": "SEAL Team Season 04 Episode 13 - Do No Harm [1080p].mkv"
"quality": {
"quality": {
"id": 5,
"source": "web",
"resolution": 720
"revision": {
"version": 1,
"real": 0,
"isRepack": false
"language": {
"id": 1,
"name": "English"
"mediaInfo": {
"audioChannels": 2,
"id": 9964
"hasFile": true,
"monitored": true,
"id": 6686
So I suggest adding the naming
object seen in the second code-block.
