Show downloading same episodes and replacing over and over again
Not sure if it’s something I’ve done or a recent change, but specifically with the show Jeopardy! (note the ! which is part of the title and causes all kinds of other issues). In some cases it’s done this 18 times in a row now. From what I can tell it just keeps replacing with the exact same download, same quality, etc.
The only change I’ve made recently is to turn off the NZBDrone folder on the advice of Markus here: https://github.com/Sonarr/Sonarr/issues/935
But I’m sure this has been going on much longer than that. Here’s an example of my recycle bin folder showing multiple copies of this. Not sure if this is a bug or if something else is going on or if the ! is causing issues (it plays havoc with Transmission currently – it dupes itself over and over again there)
And here’s some history for this file (and just to be clear this is not the only one, there was just a huge batch of about 20 that I cleared out today that download completion didn’t take care of so I had to go back to using the drone factory folder technique.
I believe this issue is fixed in develop and will be in master soon, I pushed the changes up recently, build 2.0.0.3573 or higher.
