So had to move all my libraries around.
So a lot of my links have changed. i.e. the drive.
Is there a way to fix this with out going into each show?
Thanks
Yes, use Series Editor.
But wil that fix up the link?"
c\shows\A to d\shows\A
Yes… Changing the root folder there will keep the series folder intact and just replace the root path as long as the series folders are named the same it will work.
thanks it appricated
