Just wondering if it would be possible to move settings out of the db. If I want to erase the db and do a new re-scan, all indexer data and other settings are removed. Would be nice to just be able to delete db and just tv data be removed. Thanks.
It’s in several database tables, so you just need to learn bit of sqlite kung fu.
Or
Just thought it would be convenient to have this added in the program. I’m not a programmer so learning sqlite kung fu just doesn’t sound like fun. Just want to remove from the db, not delete files. Thanks anyway.
The issue covers removing the series from Sonarr with an option to delete the files, which would achieve what you want without restructuring the entire database.
That sounds great…thanks.
