Sonarr version (exact version): 3.0.8.1507
Mono version (if Sonarr is not running on Windows): 6.12.0.122
OS: ubunutu 22.04 docker image
3.0.8.1507-ls149 by linuxserver.io
Description of issue: When trying to save settings changes nothing saves. For example if I try change logs from info to debug and press save it will not save.
I am also trying to update the IP of my downloader as it has moved server. When I enter the new IP and press test it tests successfully but when I press save I just get a red exclamation mark over the save button. I also can delete the existing one
