Sonarr version: 2.0.0.3732
Mono version:3.10.0
FREENAS 9.10.2:
((Debug logs)): http://pastebin.com/DiBiHe2j
The problem is whenever i want to access setting after i installed sonar through freenas plugins to change torrent downloader/indexer and profiles but whenever i tried to access the setting tabs it just give me continues load of death, I left it there for like a few minutes usually before i did fresh install of freenas it seem to work fine. This could be issue my router (IPFire) because this problem happens after i upgraded and reinstall my network. I have disabled squid proxy but still result in same problem.
Your debug logs don’t show anything because they only show startup messages (and debug logging isn’t enabled in settings).
Which browser are you using?
It’d be helpful to see any errors in the browser’s development console (either the Console or the Network requests).
That is a really old version of Sonarr, you should definitely update Sonarr.
