Setting up Sonarr on Mac Mini
Hey all! Need some help here. I’ve had some experience setting up on a PC, but this is the first time I’ve tried with a Mac. A bit lost!
I tried following some of the suggestions on the site, including installing homebrew. I was able to do that, but couldn’t get homebrew cast to install. I also installed Monoframework, although so far it hasn’t done anything to allow me to open Sonarr.
So, I am pretty much starting from scratch and I am not super savvy when it comes to the back end tech side of things.
I appreciate your patience and any help you can offer! :slight_smile:
If you grab the zip release of Sonarr it should setup everything for you including mono. Once you run Sonarr you will need to connect to the web interface, http://localhost:8989/
I have just set this up on a Mac ( aside from my lack of Sabnzbd skills ) it was fairly straight forward. I used the files Markus101 mentions.
This article explains how to autostart on OS-X, may look scary if never used a Mac before but is straight forward.
