Synology devices don’t have libcurl.so.3 available in /lib. (libcurl.so.4.3.0 is the main file, libcurl.so.4, libcurl.so are the available symlinks)
Creating a symlink (from /lib/libcurl.so.4.3.0 > lib/libcurl.so.3) works, but that’s not feasible for us (system libs, not retained after DSM updates). If we package curl along with Sonarr, the file and symlinks have the same name as above.
So, would it be possible to add a fallback to libcurl.so in there? The only other alternative I can see is that we package curl, create our own symlink for .3 within the Sonarr package, and see if we can tell Sonarr to look there.
/edit: Might be just as easy to patch Sonarr during packaging to change the target, so that’s another way to fix it.
But then the edit of dllmap os=“linux” dll=“libcurl.dll” target=“libcurl.so.4.3.0” should work, and I’m still not getting it up and running.
I did notice libcurl.dll is nowhere to be found on my synology.
Is there anything I can “ldd” against to see if all the required packages are available?
System.DllNotFoundException: libcurl.so.4.3.0
at (wrapper managed-to-native) CurlSharp.NativeMethods:curl_global_init (int)
at CurlSharp.Curl.GlobalInit (CurlInitFlag flags) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\ExternalModules\CurlSharp\CurlSharp\Curl.cs:75
at NzbDrone.Common.Http.CurlGlobalHandle.Initialize () [0x00028] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\CurlHttpClient.cs:224
at NzbDrone.Common.Http.CurlHttpClient.CheckAvailability () [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Common\Http\CurlHttpClient.cs:32
and
15-7-23 20:37:25.5|Debug|HttpClient|https request failed in tls error for torrentapi.org, trying curl fallback.
15-7-23 20:37:25.6|Trace|CurlHttpClient|Initializing curl failed
@Mirx_NL I can’t reproduce that. You sure it’s not caused by the optware changes you made earlier, that maybe Sonarr can’t find the correct libs anymore?
@Taloth, let me know if we need to do anything with the package (or, if maxrogers resurfaces, he can handle it ;))
@Dr_Bean So just to be clear, it is working for you on your synology?
What did you do? Did you add a libcurl.so.3 symlink in /lib to rederict to libcurl.so.4.3.0 and leave the CurlSharp.dll.config as is?
Adding the symlink was my first attempt. After I considered that changing CurlShapr.dll.config file was probably easier than adding a dependency to the package, I tried that too. Either way works, as it’s essentially the same thing.
And just to be sure it’s not a fluke on the device I’m testing on, I’m going to test it on a second device too
@Mirx_NL, what model Synology are you working with? Did a quick test on an x64-based model, and it seems I can reproduce your issue.
The one I was testing with previously was ARM-based, and that one does work. I don’t know exactly which paths Sonarr would search for the file, but there may be a relationship there.
After deinstalling Curl and libcurl from Entware (can’t remove it from Optware as git requires it) it still the same.
And as a simpleton, I also tried adding a symlink in lib64, but that also didn’t help.
Run sonarr with MONO_LOG_LEVEL=debug MONO_LOG_MASK=dll,cfg mono --debug /../../NzbDrone.exe in the console, preferably in something with a reasonably large buffer so you can scroll back, or log to file.
Also, I cross-compiled curl into the package. The error changes to Curl Error SslCaCert for Url. That’s probably because we (currently) don’t specify a CA bundle with OpenSSL. That’s something I’ve been considering for other reasons, but hadn’t done yet.
I’ll look into that in a bit more detail, maybe next week.
So I ended up with this: env PATH=/usr/local/mono/bin:$PATH LD_LIBRARY_PATH=/usr/local/nzbdrone/lib MONO_LOG_LEVEL=debug MONO_LOG_MASK=dll,cfg /usr/local/mono/bin/mono --debug /usr/local/nzbdrone/share/NzbD rone/NzbDrone.exe
After cross-compiling libcurl into the package, it ends up in /usr/local/nzbdrone/lib, and that’s searched too…it doesn’t show up here though (removed it to test properly)
Fyi, Synology uses a lot of 32b libs on the 64b-based models, and not a lot of 64b libs are available.
Usually, not a problem. However, we do compile Sonarr with a 64b toolchain…
With the 64b libcurl added in, the ELF class error disappears, and the CA-cert error comes back. So that will probably be the direction to go.
