Setting GUI resetting fields post-edit, reverting changes to default
You can see an example here: http://youtu.be/h1v7l_toN4Y
I am trying to setup folder renaming schemes, but if I click Save, or go to a different settings TAB, or edit any other field, the 2 Advanced renaming fields will reset back to default.
so you are saying they reset even after you hit the blue save button? that’s weird perhaps a permissions issue on the folder that stores you config won’t let it write anything
if you can just for S@%$ & Giggles close down drone and re-open using the .exe or command but running as administrator and try it
Also might help if we know what OS you are using
@protocol77 already spoke to @stalks on IRC, I know the issue, its on Trello here: https://trello.com/c/F5IwSJE6/601-firefox-save-changing-another-field-resets-naming
oh ok cool glad to hear it by that link it is making me think it had something to do with firefox?
I use Google Chrome mostly so i didn’t have this issue :slight_smile:
