Setting different quality profiles for same series but different seasons
Would this be possible for the dev. team to maybe implement at some point in ND?
Here is the reason I am asking.
I have some TV series that have for example S01 would be Bluray1080p but S02 etc. may be HDTV720p. If my profile is set for the highest quality, then it would grab for example a WEBDL720p or higher. The problem here is this. I find many times the HDTV720p audio is AC3, which is good enough but the WEBDL720p is AAC which I really, really hate.
I think it would be great if we can have the option to select which quality we want to apply to each season. Not sure if this would be a problem when searching “all seasons” or not.
I hope I explained myself in a way that you will understand. If not, I’ll try again. (:
Shedrock
Why not exclude WEBDL720p from the HDTV720p profile (or create you own)? Adding profiles per season would be a pretty big undertaking and likely a source of confusion for people.
Because not all WEBDL’s are AAC. I find that recently a lot of releases in that quality are though. Anyway, it would still be a nice option to have, maybe an “Advance settings tab” or something to that effect. No biggie, I will just have to keep doing them manually.
Thanks for the response.
Shedrock
Use Release Restrictions (Settings -> Indexers) to block any nzb that contains that string then.
EDIT: Added to Trello https://trello.com/c/PTPEvXt2/319-different-profile-per-season
Hmm…never thought of that. I will give that a shot.
I guess that would only be effective if it contains that text in the release name?
Thanks again.
