Setting delay profiles based on series type
It would be great to be able to set the delay profile based on either series type or quality profile. At the minute there is no way to set a tag when you create a series and i generally fine that either based on the quality or the series type i need a different delay profile as some series types need to come from torrents and others i prefer from usenet. At the minute you need to add the series then go into it and set the the tag which is easy to forget and a pain when adding many series. It would be great if the things you can set on a series like the profile, series type and potentially other info on a series was also mad available as a tag so that things that can be set based on a tag could also be controlled by these fields.
Its is something we want to do: https://trello.com/c/WksmnM7w/963-use-the-standard-daily-and-anime-tags-to-auto-match-series-type
thanks placed my vote for it
