I’m talking about The Returned which will air on A&E. Sonarr calendar says all episodes aired yesterday yet it hasn’t been on. According to this it starts on March 9 http://deadline.com/2015/01/bates-motel-the-returned-premiere-dates-ae-1201345428/
I just added it and got the correct premier date of 3/9/2015. On the calender it also correctly shows in light blue as a premier episode and is marked as The Returned (US). The only thing I can think is that perhaps you added the original French series by accident?
Hope that helps.
No. Mine is the US version
You might try a force series refresh (double-arrow). See if that fixes it.
LJ
I just deleted the series and then added it again and that seems to have fixed the problem. Maybe it had something to with when it changed over to TVDB.
Yeah that sounds logical, glad it updated for you.
