Mono version (if Sonarr is not running on Windows):4.2.2
OS: OS X 10.11.4
Description of issue: I would like to use uSeed ton DL, so i tried to add Transmission client, i specified the URL and my user and password. I get the following message : Must be a valid URL path (ie: ‘/sonarr’)
Hi, any idea ?
Here is the message :" Error: NameResolutionFailure: Error: NameResolutionFailure" and the log :" System.Net.WebException: Error: NameResolutionFailure
at NzbDrone.Core.Rest.RestSharpExtensions.ValidateResponse (IRestResponse response, IRestClient restClient) [0x001e2] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:53
at NzbDrone.Core.Rest.RestSharpExtensions.Read[T] (IRestResponse restResponse, IRestClient restClient) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Rest\RestSharpExtensions.cs:60
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.ProcessRequest (System.String action, System.Object arguments, NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x000fc] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:245
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetSessionVariables (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Transmission\TransmissionProxy.cs:129
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetConfig (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) <0x5d9aa00 + 0x00017> in :0
at NzbDrone.Core.Download.Clients.Transmission.TransmissionProxy.GetVersion (NzbDrone.Core.Download.Clients.Transmission.TransmissionSettings settings) <0x8b88150 + 0x00017> in :0
at NzbDrone.Core.Download.Clients.Transmission.Transmission.TestConnection () [0x00000] in m:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Download\Clients\Transmission\Transmission.cs:207 "
Thanks
I tried without “http://” i got the following message : " Error: ConnectFailure (Connection refused): Error: ConnectFailure (Connection refused)"
The log : " System.Net.WebException: Error: ConnectFailure (Connection refused) —> System.Net.Sockets.SocketException: Connection refused
at System.Net.Sockets.Socket.Connect (System.Net.EndPoint remoteEP) [0x000bc] in /private/tmp/source-mono-mac-4.2.0-branch-c6sr1/bockbuild-mono-4.2.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.2.2/mcs/class/System/System.Net.Sockets/Socket.cs:1235
at System.Net.WebConnection.Connect (System.Net.HttpWebRequest request) [0x0019b] in /private/tmp/source-mono-mac-4.2.0-branch-c6sr1/bockbuild-mono-4.2.0-branch/profiles/mono-mac-xamarin/build-root/mono-4.2.2/mcs/class/System/System.Net/WebConnection.cs:213
I tried using port 443 and SSL, i got the following euro message : "Authentication failure "
Hi, did i forget to something ?
Thats a problem with DNS.
Then the username and/or password you used is incorrect.
We really need to see the ((debug logs)) that were requested when you opened this thread, not just snippets from the logs as well as the settings you’re trying to use (minus the password).
Hi,
I already checked the username and password with transmission Remote GUI.
The Log :
http://hastebin.com/caxotadoko.tex
Is it enough ?
Ok, so tell me when you have time. Bye !
Okay? Its a forum… not realtime chat.
System.Net.WebException: Error: ConnectFailure (Connection refused) ---> System.Net.Sockets.SocketException: Connection refused
Possibly the wrong port, because it failed to connect at all.
One or more of your settings is wrong, perhaps someone using the same seedbox provider can help.
Please edit your posts instead of double and triple posting.
Hi, i might have found the problem, test is ok with “/transmission/” in the URL base, not what you see on the screenshot.
