Security API-Key Problem
Hello All, I am in need of some help. I am running NZBDrone Version 2.0.0.1269 and have issue with the Security API-Key. NZB Drone updated on March 17th and it appears since that time the key is not working. I hit the Reset Key button and ever since the little wheel is just spinning and doesn’t respond to all me to update the key.
I have authentication turned on with the SABnzbd username and password entered but the API field is grayed out and wont let me edit it now. Can anyone suggest what I can do to fix?
You reset the API key for drone and are entering your SAB username/password into drone, you can’t edit the API Key for drone in the UI, thats intentional.
What exactly are you trying to do?
