Hi all
im trying to set up my nzbdrone to not download the series into season folders I just cant figure it out I have renaming all set up and everything else is fine I just want to have nzbdrone just download the episode and rename it but not put it into season folders
sorry for being such a noob and thanks
for any help or advice
many thanks again
Kingkenny
You can set per series whether you want season folders. You can do that easiest via the Series Editor coz that allows you to edit all series at once.
Also, when adding a series there is an option to use season folders, which is enabled by default.
thanks guys found it thanks for all the help
Kingkenny
