Searching for better versions
Sonarr version (exact version): 3.0.3.885
Mono version (if Sonarr is not running on Windows): 6.10.0.105
OS: MacOS
I know that Sonarr is set to always look for the better version, is there a way to tell it to look for certain audio channels, or smaller files, better compressed files?
Preferred words is the only way to influence the results, though size is not possible.
