Search problem tonight
I don’t know if this has to do with the update, but Drone couldn’t find American Dad tonight. Scene posts as season 8, TVdatabase/Drone say season 9. It used to automatically convert it over which was awesome!
Tonight it wouldn’t find it, so i manually downloaded it and put in my complete folder. Drone wouldn’t find it or do anything with it. I manually changed the file to S09E18 and Drone found it and processed it.
Prior to the 4/30 update, this worked flawlessly.
Thanks,
NuTZ
Nothing changed in regards to the scene mapping it still uses thexem.de for that information, which does look correct there.
I would need to see debug logs to attempt to find the problem, but those would have been over written by now.
