Scrolling in the Series section is extremely slow no matter what type of view I select, unless I drag the scrollbar, which works fine.
This happens in Firefox 56.0.2 and Edge 42.17134.1.0
No issues in Chrome, Vivaldi, Opera.
It was fine on Waterfox until I just updated it to 56.2.2. Not sure what the previous version was, I hadn’t used/updated Waterfox in quite a while.
Firefox 62 seems fine, but Edge and Chrome (when throttled 6x) are slow, so something performance related there.
Thank you for looking into it. What do you mean by “throttled 6x”?
Edit: If I go to Add New, and type daily, I can scroll through the list of suggested shows no problem
In Chrome you can throttle the CPU for testing performance of webpages in the dev tools.
The add new page is completely different.
It seems like it is just taking tiny steps per notch of the scroll wheel, rather than a performance issue.
Settings > General > Browsing > un-check Use smooth scrolling.
This fixed the issue in Firefox, but of course smooth scrolling is preferable.
Yeah, that does seem to be the case, something with how the scrolling is being done.
Latest update (3.0.0.234) seems to have fixed the issue
Side note, 360 Total Security thinks it’s ransomware
system
Closed
8
