Sonarr version (exact version): I just pulled latest code off phantom-develop branch, had same issue
OS: Windows 10
Debug logs: n/a
Hello, I been trying to use sonarr interactive season search. Specifically with the show “American Dad”. I went to use the season pack search. It didn’t work, originally. Had to debug sonarr/jacket to figure out there is a limit param (not sure if I can changed). Ended up just adding another indexer specifically for tv pack category to workaround the limit.
However a bigger problem I noticed was that when i searched for s14 I got back s13 results. I debugged the code and saw the below code setting the search spec season number to SceneSeasonNumber which I guess was wrong in this case. I assume that is because tvdb has the wrong data or not (I found other instances where their episode lists were wrong)
I guess my question is why rely on the scene season number at all? I tweaked the code locally to just the normal season number and everything worked fine.
NzbSearchService.cs#SeasonSearch
if (sceneSeasonEpisodes.Count() == 1)
var episode = sceneSeasonEpisodes.First();
var searchSpec = Get<SingleEpisodeSearchCriteria>(series, sceneSeasonEpisodes.ToList(), userInvokedSearch, interactiveSearch);
searchSpec.SeasonNumber = seasonNumber;
searchSpec.MonitoredEpisodesOnly = true;
if (episode.SceneSeasonNumber.HasValue && episode.SceneEpisodeNumber.HasValue)
searchSpec.EpisodeNumber = episode.SceneEpisodeNumber.Value;
else
searchSpec.EpisodeNumber = episode.EpisodeNumber;
var decisions = Dispatch(indexer => indexer.Fetch(searchSpec), searchSpec);
downloadDecisions.AddRange(decisions);
else
var searchSpec = Get<SeasonSearchCriteria>(series, sceneSeasonEpisodes.ToList(), userInvokedSearch, interactiveSearch);
