Hey,
Before I begin I’ll note that this is a problem I’m also having with Radarr too, which as far as I can tell is based on the same issue.
I have Sonarr and Radarr running on a Mac with Transmission, linked in with Radarr and Sonarr in a barebones fashion. Sonarr and Radarr both periodically attempt to grab 110% of the CPU on my machine, which makes the fans go mad and certainly isn’t good for its health.
I have movies downloading to /disk/torrents/Downloads, Sonarr and Radarr symlinking to /disk/torrents/Movies and /disk/torrents/TV. I also have unrelated music stored in /disk/Music. Examination of the trace logs showed that both Radarr and Sonarr are attempting to parse the thousands of tracks in this Music folder.
A supporter from the Radarr Discord suggested that the programs were attempting to scan all the files in my torrent client, even though I had not pointed them at the Music folder, and I confirmed this given that all the CPU usage goes away when I disable Transmission in Sonarr settings.
My question is - do you have any suggestions for how I might continue to use Transmission, both for Sonarr and Radarr and for unrelated downloads, but prevent them from scanning every single download in it and causing massive lag? Thanks
