Sample erroneously detected for 4min episodes, adjustable?
Mono version (if Sonarr is not running on Windows): 5.16.0.220
OS: Ubuntu 18.10
Debug logs: Is this known behavior? If not I can upload debug logs.
Description of issue: “Samples” stuck in Sonarr queue
Actually it looks like its the only release and its being detected as a sample even though its not. The video has a 4:13 runtime and it looks complete. Is there a way to adjust sample detection?
 mediainfo 64d3981ebcde4da4bef77a1b17428438.mkv
General
Unique ID                                : 197321705861828153164599829881626075560 (0x9472C738183B5D05AE96CAD3F9ACA1A8)
Complete name                            : 64d3981ebcde4da4bef77a1b17428438.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 65.3 MiB
Duration                                 : 4 min 13 s
Overall bit rate                         : 2 165 kb/s
Encoded date                             : UTC 2013-03-09 19:08:36
Writing application                      : mkvmerge v6.0.0 ('Coming Up For Air') built on Jan 20 2013 09:52:00
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L3
Format settings                          : CABAC / 2 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 1 630 kb/s
Width                                    : 704 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate mode                          : Constant
Frame rate                               : 29.970 (30000/1001) FPS
Standard                                 : NTSC
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.161
Stream size                              : 50.5 MiB (77%)
Writing library                          : x264 core 65
Encoding settings                        : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / keyint=300 / keyint_min=30 / scenecut=40(pre) / rc=2pass / bitrate=1630 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.601 NTSC
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.601
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 13.5 MiB (21%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Menu
00:00:00.000                             : en:Chapter  1
00:02:12.096                             : en:Chapter  1
I’m guessing this isn’t tunable… https://github.com/Sonarr/Sonarr/blob/7818f0c59b787312f0bcbc5c0eafc3c9dd7e5451/src/NzbDrone.Core/MediaFiles/EpisodeImport/DetectSample.cs#L108
No it’s not configurable. You can use Manual Import (on Wanted: Missing) and ignore the rejections to force it to import.
