Sample downloaded
Sonarr tried downloading “The.Last.Ship.S02E01.1080p.HDTV.X264-DIMENSION-NZBgeek” and after downloading it was considered a “sample” file as it is just around 100MB in file size. Why didn’t it not download the correct non-sample file? Will it only download the next file in the list if the initial download failed? I had to manually delete and blacklist the sample file and manually search for the correct release (3.7GB).
Based on that title Sonarr has no way to know thats a sample only. Set a minimum allowed size.
Ok. Are there any recommended size ranges for all the qualities?
