Running with mono-service and/or systemd
I’m always looking to keep my system as “standard” as possible.
I have successfully run Media Browser using mono-service and I expect that nbzdrone should similarly run with no problems.
What I’d like is a systemd config file to run nbzdrone as a service. Is there someone who knows how to create systemd configuration files and has the time to help me with pointers on creating, deploying and running nbzdrone with a systemd config file, I will think good thoughts about your karma :wink:
I have updated the .bash_profile of the user I expect to be running all mono based services to include the pakorra/opensuse repository delivered mono 3.4 runtime required environment variables
My server is running Amahi Home Server on Fedora 19
Arch User Respository to the rescue!
[Unit]
Description=NzbDrone
After=network.target
[Service]
User=nzbdrone
Group=nzbdrone
ExecStart=/usr/bin/nzbdrone -nobrowser -data=/var/lib/nzbdrone
Type=simple
TimeoutStopSec=20
[Install]
WantedBy=multi-user.target
Depending on how it installs on your system, you may need to change the ExecStart line.
