Run remote script?
Sonarr version (exact version): Sonarr Ver. 2.0.0.5163
Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 4.8.1 (Stable 4.8.1.0/22a39d7 Wed Apr 12 12:00:40 UTC 2017)
OS: Ubuntu 16.04.4
Debug logs: N/A
Description of issue: This isn’t a problem/issue/bug, more of a question. I have an on grab/on upgrade/on rename script that I run, however I’m attempting to run it on a separate VM instance. Sonarr only allows me to choose local directory paths from what I can see. How can I run the script from a remote system? Should I just setup an sshfs share and do it that way, which isn’t as elegant but would work?
Thanks.
Even if you used sshfs you’d still execute it locally, it’d just be running from a remote location. You’d need to either use ssh in a local script to connect to the remote machine to run it or use a webhook to a web server running on the remote box.
