OS: windows 10
nginx: 1.9.2
Debug logs (posted to hastebin or similar): http://pastebin.com/MWByj3Bp , http://pastebin.com/iSvX8Qat , https://paste.ee/p/rXahL
I have nginx installed with reverse proxy configured for all my apps, sabnzbd, torrent, couchpotato, etc. However since ive enabled this within sonarr. It hangs for a long time unless i load it from the same machine sonarr is on. Nzb360 refuses to load it since it times out and if i access it via my domain or external ip via a browser it takes forever to load. Every other app is fine, machine is beefy enough, upload speed is good enough. Only happens once i fill in the setting for reverse proxy path e.g. /sonarr.
server { listen 80; server_name my domain, 192.168.1.2; location /sonarr { proxy_pass http://127.0.0.1:8989; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; }
