Retain Home Page Configuration
Sonarr version (4.0.10.2544)
Windows 10
Hi, I am new to Sonnar.
I have a couple of small issue that I would like sorted please.
When I start Sonnar on my PC I have to go in to the “Sort” dropdown and reapply the “Next Airing” setting every time. Also it doesn’t retain any changes I make in the Options menu.
Is there a way to retain changes on the Home Screen?
Thanks in advance.
Rod.
It should retain the setting.
Are you running as Service or systray? Either way, make sure it is running with admin rights so that it can save changes to the config.
Hi Fanboy, Thanks for the reply. My Nephew set it up on my QNAP NAS, so not sure what I am running. As he set it up it is most likely he has the Admin rights. Is there an easy way for me to get Admin rights? If not, I will see if he can set them up for me.
Rod.
UI settings are saved in the browser. Do you clear all settings when closing your browser or clear the cache or something?
(I’m also not sure if those particular settings are persisted or not)
I would suggest using the calendar as one of you startup tabs instead of trying to set Next Airing as the page Sonarr opens to.
