Sonarr version (exact version): 2.0.0.5283
Mono version (if Sonarr is not running on Windows): 5.16.0.179
OS: Ubuntu 18.04.1 LTS
Debug logs: https://pastebin.com/JHYn2MMC
My final goal is:
Shows added will by default only download files with the following words contained:
DKsubs, custom, customdk, retail, nordic, sublime, rapidcows, substance, dksubs
I would like to be able to manually make exceptions for some shows, which aren’t matched with the above.
I have made a restriction so that every series must contain the following words: DKsubs, custom, customdk, retail, nordic, sublime, rapidcows, substance, dksubs
by default (no tag). This seems to be working wonderfully, I always get a release i need… The problem is that when I need to make an exception (some shows aren’t released by the mentioned groups).
What I’ve tried:
1 Restriction with must not contain “test”, nothing in must contain:
1 Restriction with must contain: “1080p, 720p”
2 Restrictions, one for must contain: 1080p and another for must contain: 720p
each of them with a tag, that I’ve then applied to the series in question.
They seem not to apply, so I’m guessing the default profile overrides the options.
How would you go about setting this up?
Thanks in advance
