Hi,
In my Sonarr, I’m looking for VOSTFR content.
At the moment, my defined restriction rules are :
- Exclude the word FRENCH
- Must contains the word VOSTFR
My problem is that some release are tagged with SUBFRENCH, which is equivalent to VOSTFR.
Is it possible to get an “OR” in must contains? (VOSTFR or SUBFRENCH)
It will create a conflict between must contains SUBFRENCH but exclude FRENCH?
Thanks
Must contain is already an OR statement.
Sounds good.
So what will happend with must contains SUBFRENCH but exclude FRENCH?
NMe
4
Why not give it a try and see what happens with a manual search? It’s not like something could break.
But to answer your question: it should work the way you want it to.
Taloth
5
exclude trumps must contain, so he should add the appropriate separator to the exclude token, .FRENCH. for example.
Thanks Taloth for this precious information.
I will try.
system
Closed
7
