Reset Sonarr completely?
I had an older install of nzbdrone back when I was trying out usenet, but ended up not using it since I really wanted to use torrents. Now with the new torrent support, I’m giving sonarr a fresh look, but I have all my old settings that are badly out of date – is there a way to create a “virgin” sonarr on a Raspberry Pi?
Delete this folder: ~/.config/NzbDrone (from the user thats running Sonarr).
Excellent! That did it!
Hi Markus, what is the equivalent for Windows?
C:\ProgramData\NzbDrone (You can always get the correct path from System: Status, its the AppData Directory).
This topic was automatically closed after 2 days. New replies are no longer allowed.
