Would it be possible to save this information: Screenshot ( http://d.pr/i/V5Yx/3mJLNIZz )
and present graphs or statistics of which indexer provided the most tv shows, genre etc.
It would really help me, and probably others to see that information.
This is not something we’re going to consider at this time.
Right now you could use the API to get all the records in History, link the series via the Series ID and you would then have the genres as well. The API docs are here: https://github.com/NzbDrone/NzbDrone/wiki/API
PS you don’t need 19+ indexers, 2 or 3 is enough. The more you have, the longer each search/RSS Sync will take.
