I did a search, but there is a LOT to search here, so my apology if this has been covered.
I find that existing episodes on disc are being replaced in one of two ways:
1). With newer releases of same episode in same resolution but in a foreign language.
2). With full downloads of full DVD rips. Not episode, but iso or img images.
Can I get a quick pointer on how to set this thing to stop that from happening?
Does Sonarr not have the correct quality detected for the existing files?
Is the cutoff set above the current quality?
Does the release contain a language in the name?
Can you block that category on the indexer?
Does the release contain any mention that it’s an full disk release?
Both these issues are potentially problems that will require a new indexer or changes to which categories Sonarr checks. We’ll need some concrete information (exactly what Sonarr had and what it replaced it with) to troubleshoot further.
Sonarr version (exact version): Mono version (if Sonarr is not running on Windows): OS: ((Debug logs)): (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here)
